Warning message
CDP Error? trying...
Aug 5th, 2002
Dear Sir!
Cisco write, that CDP works over FrameRelay (as SNAP-capable link).
But however hard I may try, but I can't see Frame Relay switch by CDP in my lab!
What CDP configuration must I use on my FrameRelay switch?
Best regards,
Nick
vmiller Mon, 08/05/2002 - 14:14
  • Gold, 750 points or more
It may be disabled on serial interfaces. gointo config mode for the Interface
and try a CDP enable....
hth
mljohnson Mon, 08/05/2002 - 14:18
I assume that the FR switch is a cisco IOS device? If not, this won't work. If it is, make sure that you have recent code on the devices, as there could be bugs (although I don't see any specific bugs right now could apply). In terms of configuration, there isn't a lot to it besides "CDP run" (global) and "cdp enable (per interface).
