Warning message
No PBR matches on catalyst 6509 since upgrade to 12.1(8b) E9
Aug 5th, 2002
Since I upgraded my L3 switches to 12.1(8b) E9, on May 18, I'm getting " Policy routing matches: 0 packets, 0 bytes on a 'show route-map command". I'm using (1) MSFC2 module in each of my L3 switches.
The Catalyst version is 6.3(5).
The policies DO work as configured,(end-users are happy)., but I'm wondering if this is another bug or if I'm missing something in my configuration.
kschung Wed, 08/07/2002 - 19:50
It's working perfectly. Remember that there is no MLS with Sup2/MSFC2. Your traffic is being switched in PFC(hardware) completely so MSFC will not record any traffic. With the older code, PFC may have been punting PBR traffic to MSFC for processing. In anycase, it's nothing to worry about.
kevin
