Warning message
MWI still ON after retrieving the voice mail from an external phone
Aug 6th, 2002
HI,
The new voice mail was been retrieved from an external call but the MWI in the IP phone remains ON even though there is no messages found. The only way to turn off is by dailing the MWI off extension.
The version I am using is 3.0.
Is this a feature or it is a bug.
Please advise
With Regards
Chin Lam
Hi Chin,
I have not used Unity 3.0 and so I do not know if this is a bug or not. CIsco recommends that you use the latest software releases and patches as much as possible to ensure that bugs are limited to a minimum. You can check out issues concerning this on Cisco'c website. It should be in the release notes for the different versions of Unity.
You could also try to solve this by scheduling a "resync" to occur at a specific time everyday to ensure that all MWIs are updated. For an imediate solution, you can refresh the MWI for the particular subscriber. This is done from the SA interface (For scheduling, check under the switch menu).
There is also a detailed troubleshooting guide for MWIs on the cisco website. I can not recall the actual URL but a search should reveal the document.
Hope this helps.
lindborg Tue, 08/06/2002 - 07:59
  • Cisco Employee,
There were some MWI bugs ironed out in the 3.0(x) line along the way. You can check out the 3.1(4) release notes and search the resolved issues for "MWI" to get an idea.
You should also check out a couple of the TAC tech tips pages for MWI problem troubleshooting here:
http://www.cisco.com/warp/customer/788/AVVID/Unity_MWI_Exchange.html
http://www.cisco.com/warp/customer/788/AVVID/cm_mwi_config_issues.html
