Warning message
Pix 501 - 110001 No route to ___ from ___
Aug 6th, 2002
  • Bronze, 100 points or more
I have a Pix 501 with default configuration 192.168.1.1
and a 3Com ISDN Lan modem 192.168.2.1
on the external port.
To connect to the internet I open 192.168.2.1
and I connect trought the ISDN modem interface.
The problem is that I can't browse any site.
The Pix in the log say:
"110001No route to xxx.xxx.xxx.xxx from 192.168.2.1"
Can you say me how to solve this problem
using the PDM interface.
Thanks.
I thought that was more simple to configure the Pix :-(
Mark.
yusuff Tue, 08/06/2002 - 23:24
  • Cisco Employee,
This message indicates a route lookup failure. A packet is looking for a destination IP address which is not in the routing table.
Check the routing table and make sure there is a route to the destination.
You need to put a default route eg
route outside 0.0.0.0 0.0.0.0 {next-hop address}
R/Yusuf
Anonymous (not verified) Fri, 08/09/2002 - 10:40
I have solved inserting a Static Route outside 0.0.0.0 0.0.0.0
and the Defaulg Gateway = Modem IP.
