Warning message
1 to 1 Nat on Pix 501
Aug 6th, 2002
I am in need of some real help here. I have to setup a Cisco Pix 501 firewall at work. First I guess it would help to know my setup and what it is that I would like to do:
Cisco 678 router is my gateway 65.xxx.xxx.14
then I want to have the following done.
outside Ip 65.xxx.xxx.9 mapped to 10.0.0.10(allow Terminal Services, PCAnywhere)
outside Ip 65.xxx.xxx.10 mapped to 10.0.0.11(allow Terminal Services, PCAnywhere)
outside Ip 65.xxx.xxx.11 mapped to 10.0.0.28(allow Terminal Services, PCAnywhere)
outside Ip 65.xxx.xxx.12 mapped to 10.0.0.95(allow Terminal Services, PCAnywhere)
outside Ip 65.xxx.xxx.13 mapped to 10.0.0.1(allow www,smtp,pop,443)
Here is my current config:
PIX Version 6.1(3)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxxxxxx encrypted
hostname xxxxxxxxxxx
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
name 65.xxx.xxx.13 firewall
name 10.0.0.1 server
access-list fromoutside permit tcp any any eq pop3
access-list fromoutside permit tcp any any eq www
access-list fromoutside permit tcp any any eq smtp
access-list acl_outside permit tcp any host 65.xxx.xxx.9 eq smtp
access-list acl_outside permit tcp any host 65.xxx.xxx.9 eq www
access-list acl_outside permit tcp any host 65.xxx.xxx.9 eq 443
access-list acl_outside permit tcp any host 65.xxx.xxx.10 eq 3389
access-list acl_outside permit tcp any host 65.xxx.xxx.10 eq 5631
access-list acl_outside permit udp any host 65.xxx.xxx.10 eq 5632
access-list acl_outside permit tcp any host 65.xxx.xxx.11 eq 3389
access-list acl_outside permit tcp any host 65.xxx.xxx.11 eq 5631
access-list acl_outside permit udp any host 65.xxx.xxx.11 eq 5632
access-list acl_outside permit tcp any host 65.xxx.xxx.12 eq 3389
access-list acl_outside permit tcp any host 65.xxx.xxx.12 eq 5631
access-list acl_outside permit udp any host 65.xxx.xxx.12 eq 5632
access-list acl_inside permit ip 10.0.0.0 255.255.255.0 any
access-list acl_inside permit tcp 10.0.0.0 255.255.255.0 any
pager lines 24
logging on
logging timestamp
logging buffered notifications
logging trap warnings
logging history notifications
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside firewall 255.255.255.0
ip address inside server 255.0.0.0
ip verify reverse-path interface outside
ip audit info action alarm
ip audit attack action alarm
pdm location server 255.255.255.255 inside
pdm logging notifications 512
pdm history enable
arp timeout 14400
global (outside) 1 65.xxx.xxx.11
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp firewall pop3 10.0.0.2 pop3 netmask 255.255.255.2550
static (inside,outside) tcp firewall smtp 10.0.0.2 smtp netmask 255.255.255.2550
static (inside,outside) tcp firewall www 10.0.0.2 www netmask 255.255.255.255 00
static (inside,outside) 65.xxx.xxx.9 10.0.0.10 netmask 255.255.255.255 0 0
static (inside,outside) 65.xxx.xxx.10 10.0.0.11 netmask 255.255.255.255 0 0
static (inside,outside) 65.xxx.xxx.11 10.0.0.28 netmask 255.255.255.255 0 0
static (inside,outside) 65.xxx.xxx.12 10.0.0.95 netmask 255.255.255.255 0 0
access-group acl_outside in interface outside
access-group acl_inside in interface inside
route outside 0.0.0.0 0.0.0.0 firewall 1
timeout xlate 0:05:00
timeout conn 0:05:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 s0
timeout uauth 0:04:00 absolute uauth 0:02:00 inactivity
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.0.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet server 255.255.255.255 inside
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 10
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
I dont need or want any extras and I dont know if I have stuff in here that falls under the "extras" category. I just need to accomplish what I have listed above and I will be the happiest person on the planet Any help would be greatly appreciated. Thanks very much.
paqiu Tue, 08/06/2002 - 16:13
1 "route outside 0.0.0.0 0.0.0.0 65.xxx.xxx.14"
2 combining "access-list fromoutside" into "acl_outside", because only "acl_outside" applying to the outside interface.
3 take off "ip verify reverse-path interface outside" because it proivde extral secure but sometimes will deny some incoming traffic.
Hope above suggestions help.
Best Regards,
chooser1 Wed, 08/07/2002 - 08:56
Hey thanks a lot. I will try this when I get back to the office. Cant wait to see if it works.
