Warning message
Misbehaving 1710 IOS Loads (Supposedly INSUFFICIENT RAM)
Aug 6th, 2002
OK...
Start with a running 1710 with a factory-installed software load of 12.2(8)T1. TFTP a new image 12.2(8)YJ, to take advantage of new EZVPN feature set. OOPS! That requires 48MB RAM (this router only has 32).
So, I downgrade to 12.2(4)YA2, which also has old version of EZVPN and fits in 8/32. No dice ... still get "SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!". I then proceed to load EVERY available software image, including the original one which I copied directly from the router before doing anything.
This little @#$!)(% will now not boot with ANY image. Is there something I'm missing here?
Thanks for any clue...
Mike
s.lemberg Wed, 08/07/2002 - 01:51
hi mike,
please check the memory at the rommon.
i had a similar problem with a 1720. after an upgrade the
router wrote "insufficient memory". the "meminfo"-command
at rommon showed me 0kB memory.
i took out the memory and put it in again. after that the router
worked fine again.
maybe it works with your router, too.
regards
sascha
mpervere Wed, 08/07/2002 - 04:20
Well, I had never looked at it there, but unfortunately the NVRAM comes up showing 32 there too. IOmem is reporting at 5% of that, but I don't see anywhere to play around with that in ROMmon. Sounds like probably time to call TAC after a couple of cups of coffee...
Thanks!
Mike
