Warning message
Boot load upgrade for 7200VXR
Aug 8th, 2002
The Cisco 7206 I'm using is running an older version boot load. Where can I download the latest bootcode from and also what is the procedure for upgrading the boot code of this router.
CISCO1#show ver
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(3b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 26-Oct-01 00:31 by pwade
Image text-base: 0x600089C0, data-base: 0x61362000
ROM: System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMENT SOFTWARE BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(13)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
CISCO1 uptime is 2 weeks, 1 day, 19 hours, 5 minutes
System restarted at 17:39:57 utc Tue Jul 23 2002
System image file is "sup-slot0:/c7200-is-mz.122-3b.bin"
cisco 7206VXR (NPE400) processor (revision A) with 114688K/16384K bytes of memor
y.
Processor board ID 23664918
R7000 CPU at 350Mhz, Implementation 39, Rev 3.2, 256KB L2, 4096KB L3 Cache
6 slot VXR midplane, Version 2.3
Last reset from power-on
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
8 FastEthernet/IEEE 802.3 interface(s)
16 Serial network interface(s)
8 Channelized E1/PRI port(s)
8 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
46976K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
donewald Thu, 08/08/2002 - 07:44
  • Silver, 250 points or more
