Warning message
snmp config commands
Aug 9th, 2002
I have some questions about setting up an snmp config.
These are probably really basic questions but I just wanted
to get some clarification for my own benefit. I tried
looking up the first 2 commands using the TAC command tool
look up and didn't get anywhere.
1a-What is the function of snmp-server chassis-id?
1b-Is it a system generated integer or assigned
(like using the box serial number)?
2a-What is the function of snmp-server engineid?
2b-Is it a system generated integer or assigned?
3-I've looked through the document "Cisco IOS SNMP
Traps and How to Configure Them". I just want to
be sure I understand because I'm seeing some
flakey Ciscoworks/Openview behavior and I want to be
sure it's not config related.
3a -If you use:
snmp-server community <name> RO
snmp-server community <name> RW
snmp-server host x.x.x.x <community> <trap1> <trap2> <trap3>
you *must* also use
snmp server enable traps <trap1>
snmp server enable traps <trap2>
snmp server enable traps <trap3>
3b-If you use:
snmp-server host x.x.x.x traps < community>
You will get all trap notifications.
Thanks in advance.
rmushtaq Fri, 08/09/2002 - 08:52
  • Blue, 1500 points or more
1a- This is to assign the chassis serial# in the device config especially for routers so that when you poll the router chassis serial #, you get the correct value. See the tech tip for further details on this:
http://www.cisco.com/warp/public/477/SNMP/chassis.shtml
1b- It's not system generated, though if you don't specify this in the config, the output of 'sh snmp' command that lists the chassis field may show some number which will not match with the actual chassis serial #
2a- Is used to configure a name for either the local or remote SNMP engine on the router. See the IOS command reference for more details.
kimlong Fri, 08/09/2002 - 10:05
That was very helpful. I don't know what I did wrong, but I couldn't
turn up anything when I tried to find snmp-server chassisid
using the look up tool. Your link provided exactly the info I needed.
