Warning message
What is needed for Cisco 2600 router and Cable internet...
Aug 9th, 2002
I have a Cisco 2600 router that my company as lended to me, and i want to set it up with my cable internet modem. What WIC do I need to make it work? It currently has a 56k/64K serial DSU/CSU. I will be connecting about 10 computers through the router to the internet via NAT.
Dennis
marlon-chung Sun, 08/11/2002 - 18:34
You won't need an additional WIC. What you might need is an additional ethernet port depending on what type of Cisco 2600 you have. In other words if you have a Cisco2611, it comes with 2 ethernet 10BT ports. A Cisco2610 only comes with one ethernet 10BT port.
If you already have a Cisco2611, then you are all set. Either connect the cable modem's ethernet port into a hub/switch or directly into one of the Cisco2611 ethernet port and use the other to connect to your internal LAN.
