Warning message
827 Adsl router vpn to Pix
Aug 12th, 2002
Hi all
I have a problem connecting an adsl router with site-to-site vpn to pix
My first problem is that the ip address of the dialer is negotiated
The second is that the telecom company and the isp do not support PPPoE
Can anyone tell me how to make this connection established?
Will I after establishing the connection be able to exit to the
Internet vie my router?
Please help
awaheed Fri, 08/16/2002 - 12:32
  • Cisco Employee,
You can definately go out to the Internet after setting up the VPN on the Router as only the traffic which we specify in the access-list would be encrypted going through the VPN tunnel. as for the Dynamic address, it would not be possible to make the PIX as a LAN-to-LAN endpoint as it doesn't support Dynamic LAN to LAN peers.
Hope this helps,
Aamir
