Warning message
NMS Integration with solaris 8
Aug 12th, 2002
We are atempting to install the CiscoWorks 2000 NMS integration on a Sun server with Solaris8 and NNM 6.2.
Actualy the NMS is located on a Sun Machine and CiscoWorks2000 on a windows 2000 server. So I thought it was possible to install only the NMS integration on the Sun Machine but every time I start the script it exits after the swap control without giving any reason.
Dose anyone have a solution to this?
I had a look at the CCO software updates but there is no solution or patch.
Sandro Ginnari
