BANDWIDTH LIMIT DOES NOT WORK?!
HI.
I'm using CAR bandwidth limit to limit ftp outbound connection to external ftp site.
I have an access listi like this:
access-list 102 permit tcp any any range 20 21
and on serial interface connected to internet i have
rate limit output access-group rate-limit 102 8000 1500 2000 conform-action set-prec-continue 4 exceed-action drop.
Now if i connect to an ftp site my bandwidth is not limited to 8kb/s, but continue to download at high speed rate.
I0m missing somethings?
Thanks.
If i remove rate-limit
bacarpenter Wed, 08/14/2002 - 05:17
You have an out bound rate limit set on the serial interface. i believe this will only work if you're sending to an ftp site, not receiving an ftp download from the internet.
I am also experiencing the same problem even I apply the rate-limit for inbound FTP traffic ,
access-list 102 permit tcp any any eq ftp
rate limit input access-group rate-limit 102 8000 8000 8000 conform-action transmit exceed-action drop
I was wondering after applying the rate limit, I tried to download a 2MB file from one FTP site, MY cute-ftp is showing 32Kbps download speed rate..
Please correct me If the config is wrong..
thanks in Advance
Ganesh
bacarpenter Wed, 08/14/2002 - 08:35
The rate limit command doesn't look right. I think it should be
rate limit output access-group 102 8000 1500 2000 conform-action set-prec-continue 4 exceed-action drop
Drop the second rate-limit command. It means that access list 102 is a rate-limit access list as defined by the global access-list rate-limit command.
