Warning message
827 router reboots
Aug 13th, 2002
We have an 827 DSL router that intermitantly re boots. There are no errors in the show logging, but sh ver has the following. The relevent part being
System returned to ROM by error - a SegV exception, PC 0x807EDE80
Thanks in advance
Danny
IOS (tm) C820 Software (C820-K9OSY6-M), Version 12.2(8)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 21-Jun-02 21:52 by ccai
Image text-base: 0x80013170, data-base: 0x8090A790
ROM: System Bootstrap, Version 12.1(1r)XB1, RELEASE SOFTWARE (fc1)
uni-dev uptime is 12 hours, 8 minutes
System restarted at 01:57:22 METDST Tue Aug 13 2002
System image file is "flash:c820-k9osy6-mz.122-8.T5.bin"
CISCO C827 (MPC855T) processor (revision 0x701) with 31744K/1024K bytes of memory.
Processor board ID JAD05480U6B (1767387140), with hardware revision 0000
CPU rev number 5
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
8192K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
mljohnson Tue, 08/13/2002 - 09:51
We need the output of "sh stack" to verify the cause of the crash; however, my guess is that this is potentially a new bug, and so you may want to open a case with the TAC so that they can submit a new bug report if necessary, or get you the latest 12.2T image that may have a fix.
danburns Tue, 08/13/2002 - 12:49
show stack as requested
uni-dev#show stack
Minimum process stacks:
Free/Size Name
5552/6000 CPE MMI SNMP
8892/12000 Init
9840/12000 HTTP Server
9936/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 0 9000/9000 ADSL Dying Gasp Interrupt
4 22030360 8256/9000 MPC860 CPM INTERRUPT
5 3219 8772/9000 ADSL Ctrl Interrupt
7 18760218 8904/9000 TIMER INTERRUPT
System was restarted by error - a SegV exception, PC 0x807EDE80
Compiled Fri 21-Jun-02 21:52 by ccai (current version)
Stack trace from system failure:
FP: 0x811BD2F8, RA: 0x8013F08C
FP: 0x811BD310, RA: 0x807F37A8
FP: 0x811BD320, RA: 0x807F40D4
FP: 0x811BD360, RA: 0x801574EC
******* Information of Last System Crash **********
mljohnson Wed, 08/14/2002 - 10:55
Yes, this looks like a new bug. I would suggest you open a case with the TAC to try the latest 12.2T code, otherwise a bug report will need to be submitted. It will help the TAC is you can verify whether or not you can reproduce the problem, and what action may be causing the crash.
danburns Wed, 08/14/2002 - 13:28
We have another 827 with a very similar configuration that does not crash
The router that is haveing the problems has crashed again with the same trace.
Danny
tepatel Wed, 08/14/2002 - 20:12
  • Cisco Employee,
Open a TAC case for this issue and present "sh stack"..Tejal
