int ATM WS-X2961-XL for 2924M-XL-EN
Aug 13th, 2002
hello,
I use a switch 2924M, with an interface ATM WS-X2961-XL . With the boot I do not see in the show version the interface ATM.
when I return in configuration mode, I nothing commands on the level interface ATM.
I think that I am not with the good versions of code on the level of the 2924m-xl frame.
Code 2924M:c2900XL-c3h2s-mz.120-5.WC3b.bin code ATM sloT 1: c29atm-m-MX-120.7-XF.bin
sh ver :
Switch>sh ver
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC3b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 15-Feb-02 10:14 by antonino
Image text-base: 0x00003000, data-base: 0x00337600
ROM: Bootstrap program is C2900XL boot loader
Switch uptime is 53 minutes
System returned to ROM by reload
System image file is "flash:c2900XL-c3h2s-mz.120-5.WC3b.bin"
cisco WS-C2924M-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K bytes of memory.
Processor board ID FAB0621Y1M9, with hardware revision 0x03
Last reset from warm-reset
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:09:B7:CD:0A:C0
Motherboard assembly number: 73-3425-10
Power supply part number: 34-0920-01
Motherboard serial number: FAB062150ID
Power supply serial number: PAC051701B1
Model revision number: A0
Motherboard revision number: F0
Model number: WS-C2924M-XL-EN
System serial number: FAB0621Y1M9
Module Ports Model HW Version SW version
1 1 WS-X2971-XL 0 12.0(7)XF
Configuration register is 0xF
Prashanth Krishnappa Tue, 08/13/2002 - 15:24
  • Cisco Employee,
Are you able to session into the ATM module by issuing a "session 1" command?
