Warning message
IPSec AH or ESP in tunnel mode
Aug 16th, 2002
When using IPSec with tunneled mode-AH or tunneled mode-ESP, what are the new SRC and DST IP address used to construct the IPSec's outer IP HDR ? And Why ? And how does Cisco (and other vendors) do this ? What are the Cisco command to use ? Thanks !
paqiu Fri, 08/16/2002 - 17:26
Here is a good documentation explain AH and ESP, also the difference between tunnel mode and transport mode:
http://www.cisco.com/warp/public/cc/techno/protocol/ipsecur/ipsec/prodlit/dplip_in.htm
Here is a basic one with config explaination:
http://www.cisco.com/warp/customer/105/IPSECpart1.html
The command to choose AH, ESP and mode is in the "crypto transform-set"
crypto ipsec transform-set MamaBear ah-md5-hmac esp-des mode
Please check above links for more details.
Best Regards,
