Warning message
DMZ access to outside interface
Aug 16th, 2002
PIX 515 with 6.2
After creating translations to the inside network from the DMZ and applying access lists to the DMZ interface, the hosts on the DMZ can no longer access the outside interface. How can I allow these hosts access to the outside interface?
alexis.fidalgo Fri, 08/16/2002 - 12:18
you need to create a translation dmz-outside
now you have a traslation (nat , nat 0 or static) between inside-dmz
ok, to get outside from dmz, you might create another nat or static statement.
