QoS configuration
ranairfan
Two sites are connected with eachother at 2Mb banwidth. At both the sites I have 3640 routers. I need to send video files from one location to another location. My major traffic is video files. I want to implement QoS so that my video traffic can get maximum bandwidth/priority over others. How I will configure QoS for this purpose. kindly help me indetail I never implemented it earlier. Also tell me the which configuration commands will be used.
simon.machielse
There are a lot of Cisco CCO documents on QoS on the Web. If you have a login you can take a look at these documents. Could you tell us what kind of protocol/program you use for transmitting/playing the video?
sachon
You need to explain in more detail what you are trying to accomplish. Are trying to FTP video files? live streaming? video conferencing? What b/w does this stream require? What else is using the pipe?
