Warning message
TCP Giveups
Aug 20th, 2002
Having issues with DLSW peer dying. Maybe some of the keepalives are not being processed properly?. Packet output on Serial, and local interface indicates no drops. No buffer failures, missess, very few trims, nothing to be concerned about I would think. There are, though, many Giveups in the "show tcp" stats.... Anyone know what this means?
Event Timers (current time is 0x13F82CB4C):
Timer Starts Wakeups Next
Retrans 10449 0 0x0
TimeWait 0 0 0x0
AckHold 10450 0 0x0
SendWnd 0 0 0x0
KeepAlive 0 0 0x0
GiveUp 10448 0 0x0
PmtuAger 0 0 0x0
DeadWait 0 0 0x0
Gilles Dufour Tue, 08/20/2002 - 04:59
  • Cisco Employee,
It means that each time we don't get an ACK there is a retransmit.
However, if we don't retransmit forever,
After a certain time we 'GiveUp' retransmitting.
You should check if the other side is sending the ACK or not.
Use a sniffer trace if necessary.
