Warning message
TFTP error message: Access violation
Aug 20th, 2002
I'm trying to upload configs files and software images, using CW, from the Cisco switches (6509's) to the
CiscoWorks box and it doesn't work.
WHen I tried the same operation pointing to my machine ip address, running tftp server it worked.
We just migrated our CiscoWorks box to a newer machine. We used the backup and restore of the DB's functions
following the instructions in the CW help files.
WHen downloading config files and images (using the same options mentioned above on CW) to the Cisco
switches works great, but the problem is uploading them to the CW box.
WHen I used the "Configure Card 1" --> Category "Upload/Download" option, I get the message
TFTP Status: unauthorized access.
WHen I used the "Configure Device" --> Category "File Copy" --> Category "Copy Config File" --> From "Runtime to
Host" option, I get the message at the bottom of the window; Status: Access Violation.
The tftpboot directory is there and in the right location, the CRMTFTP service is running and there are no other TFTP
services running on the server
I checked the switches/MSFC's and don't have any of these statements either: service config or boot network.
By the way the CW box is running WIndows 2000 Server and We've disable IIS Server feature.
Thanks for your help.
thomas.chen Wed, 08/28/2002 - 11:37
  • Silver, 250 points or more
A good way to verify proper TFTP configuration is to manually push a file to the CW box. If this works well, it rules out just about anything other than an issue with CW itself.
kcreed Thu, 08/29/2002 - 11:51
Make sure the files names exist on the TFTP server directory (usually tftpboot). TFTP won't allow you to create a file that doesn't already exist.
