Warning message
thusain Wed, 08/21/2002 - 10:05
  • Silver, 250 points or more
Unfortunately, there is no support for Radius servers with VG 200 at this time. The VG200 is designed to be an AVVID gateway and the AVVID solution has its own method of colelcting CDR's using callmanager.
mveselic Tue, 10/29/2002 - 04:44
We are developing our own Radius billing solutions for one of the customers. The network is made of VG200, AS5350, ATA186, 2600/3600 and 7200 series routers, acting as gateways and gatekeepers. Unfortunatelly, only the latest 12.2.11T1 IOS for VG-200 supports RADIUS. It works fine, but we have another problem now. In our setup ATAs are using VG200s for outgoing calls. With previous IOS versions everything works fine. In RADIUS supported version ATA can place call, and I can hear voice from the other side, but they can't hear me. I tried different codecs but without success. Do you have any info on this subject or maybe solution for the problem. If you need more info, I can send configurations and drawing of the network. It's quite urgent.
