Warning message
Problem 1721 router with Vpn client 1.1
Aug 22nd, 2002
I have a 1720 router,having outside public ip address to connect to the ISP and I got a range of public ip addresses for the inside interfaces.the 1721 has ip/fw/ipsec 3DES bundle and a cryoto card .I am configuring so that vpn client 1.1 should connect to it through dialup.
The configuration is like this
crypto isakmp policy 10
encr 3des
authentication pre-share
crypto isakmp key xxxxxx address 0.0.0.0 0.0.0.0
crypto isakmp client configuration address-pool local test-pool
crypto ipsec transform-set test-tranfer esp-3des esp-sha-hmac
crypto dynamic-map test-dynamic 10
set transform-set test-tranfer
crypto map test client configuration address initiate
crypto map test client configuration address respond
crypto map test 10 ipsec-isakmp dynamic test-dynamic
interface FastEthernet0
ip address 213.x.x.x 255.255.255.x
speed auto
interface Serial0
description connected to etisalat
ip address 194.x.x.x 255.255.255.x
ip local pool test-pool 213.42.x.1 213.42.x.100
ip classless
ip subnet-zero
ip route 0.0.0.0 0.0.0.0 194.x.x.x
no ip http server
ip http port 8080
ip pim bidir-enable
When i try to ping the outside interface of the router from a pc having vpn installed(1.1) and when i give debug crypto engine command on the router,it says...."packet lost due to missing cryptomap".
Can anybody tell me where i am wrong.what extra configuration i need ?
paqiu Thu, 08/22/2002 - 06:53
Please apply the crypto map to the outside interface:
interface Serial0
crypto map test
Best Regards,
