Warning message
Duplicate Bug ID CSCdt26987 does not match to CSCdt89095 nor CSCdt78053
Aug 22nd, 2002
The bug IDs CSCdt89095 and CSCdt78053 are marked as duplicate of CSCdt26987. The first two bugs are relating to router crashes (which in my case happens too) whereas CSCdt26987 relates to a counter issue in a show command. Can somebody with insight of the internal Cisco DDTS databases verify if the information in Bug Toolkit is correct ?
Thanks.
Mat
Frederic Vanderbecq Thu, 08/22/2002 - 06:11
  • Cisco Employee,
Those 2 bugs have been duplicated to the bug CSCdt26987 because the fix for the counter issue in CSCdt26987 was going to also include the fix for the 2 other bugs. The DEs have simply decided to group the fixes together in one go. Hence the duplicates.
Gilles Dufour Fri, 08/23/2002 - 06:18
  • Cisco Employee,
I would not count on it.
12.1T became 12.2 at a certain time and if you have an issue in 12.1T it is recommended that you go to 12.2
