Warning message
Cisco Access Registrar 1.7 (UnableToAcquireResource)
Aug 23rd, 2002
Does anyone know what this means?
08/23/2002 9:34:13 name/radius/1 Warning Protocol 0 Request from MikePIX (15.6.96.138): User cosmo rejected (UnableToAcquireResource).
I can't think of any configuration changes I made. I just started to get lots of these messages in the log.
thanks
brooks
gfullage Sun, 09/01/2002 - 21:25
  • Cisco Employee,
You usually see this when you are doing external authentication (LDAP for example) with your AR setup, and AR has been unable to communicate successfully with the external user database. The cause of this could be a simple network problem if the external server is remote from the AR server, or could be that the AR server has run out of memory, etc. There should be some other messages around this one in the log that might give a better indication of what's going on.
