Cisco 2620 router config question.
Aug 26th, 2002
Could anyone please help me figure out why this configuration will not allow any connections to 206.159.159.235 (An inside static NAT route).
Using 2869 out of 29688 bytes
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname DMetalGW
logging rate-limit console 10 except errors
no logging console
enable secret ***********************************
enable password *********************************
memory-size iomem 15
ip subnet-zero
ip cef
no ip finger
ip name-server 206.231.8.2
ip inspect max-incomplete high 1100
ip inspect one-minute high 1100
ip inspect name fastethernet_0_1 tcp
ip inspect name fastethernet_0_1 udp
ip inspect name fastethernet_0_1 cuseeme
ip inspect name fastethernet_0_1 ftp
ip inspect name fastethernet_0_1 h323
ip inspect name fastethernet_0_1 rcmd
ip inspect name fastethernet_0_1 realaudio
ip inspect name fastethernet_0_1 streamworks
ip inspect name fastethernet_0_1 vdolive
ip inspect name fastethernet_0_1 sqlnet
ip inspect name fastethernet_0_1 tftp
ip inspect name ethernet_0 tcp
ip inspect name ethernet_0 udp
ip inspect name ethernet_0 cuseeme
ip inspect name ethernet_0 ftp
ip inspect name ethernet_0 h323
ip inspect name ethernet_0 rcmd
ip inspect name ethernet_0 realaudio
ip inspect name ethernet_0 streamworks
ip inspect name ethernet_0 vdolive
ip inspect name ethernet_0 sqlnet
ip inspect name ethernet_0 tftp
ip inspect name fastethernet_0_0 smtp
ip inspect name fastethernet_0_0 tcp
ip audit notify log
ip audit po max-events 100
no ip dhcp-client network-discovery
interface FastEthernet0/0
ip address 206.159.159.234 255.255.255.248
ip access-group 101 in
ip nat outside
ip nbar protocol-discovery
ip inspect fastethernet_0_0 in
speed 100
full-duplex
interface FastEthernet0/1
ip address 192.200.200.1 255.255.255.0
ip access-group 102 in
ip nat inside
ip inspect fastethernet_0_1 in
duplex auto
speed auto
interface Ethernet1/0
ip address 10.0.0.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip inspect ethernet_0 in
no keepalive
half-duplex
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static 10.0.0.2 206.159.159.235
ip classless
ip route 0.0.0.0 0.0.0.0 206.159.159.233
ip http server
ip http port 3645
access-list 1 permit 192.200.200.0 0.0.0.255
access-list 101 permit tcp any host 206.159.159.235 eq smtp
access-list 101 permit tcp any host 206.159.159.235 eq www
access-list 101 permit tcp any host 206.159.159.235 eq domain
access-list 101 permit tcp any host 206.159.159.235 eq pop3
access-list 101 permit udp any host 206.159.159.235 eq domain
access-list 101 permit tcp any host 206.159.159.235 eq 10000
access-list 101 permit tcp any any established
access-list 102 permit ip any any
access-list 103 permit ip any any
line con 0
exec-timeout 0 0
transport input none
line aux 0
line vty 0 4
Gilles Dufour Mon, 08/26/2002 - 07:16
  • Cisco Employee,
duplicate question. We'll continue the other thread and stop this one.
