Warning message
ISDN and backup interface
Aug 26th, 2002
  • Bronze, 100 points or more
I have an ISDN BRI as the backup for T1 link.If I configure the BRI interface as the backup for T1 then in the Show ISDN Status layer 1 shows as deactivated.But if I configure a dialer interface as the backup for the T1 then layer is active and backup is working properly.What can be the problem when I use a physical interface as the back up for T1 line.
Can any one advise on this.
Thanks.
tepatel Wed, 08/28/2002 - 21:10
  • Cisco Employee,
There will be no problem..If you use interface (physical or dialer) with a backup command, that interface will be in "standby" mode untill the primary interface becomes down/down or up/down....You can verify what using "sh interface xxx"
With that router will disable the layer 1 for that physical interface..
But for dialer interface, its a virtual interface used for DDR..so when you use "backup interface dialer x", only dialer interface will go in standby mode..BRI interface will remain as it is..
Its always a better idea to have backup command with dialer interface to avoid bri line with down/down mode which can trigger alarm to Some telco switches which telco people don't like that.
