Warning message
1200 password recovery
Aug 28th, 2002
hello
I can't give out the :resetall command because the AP ask for the username & password first......How can i do real password recovery that works?
tepatel Wed, 08/28/2002 - 10:28
  • Cisco Employee,
The :resetall command is valid for only 2 minutes immediately after the AP reboots..You need to enter that command immediately after Summary Status screen appears..That way It should not ask for authentication..Here is the procedure documented on cco
http://www.cisco.com/warp/public/102/wlan/pwrec-2.html#resetap
If you still can't get it working, you might want to open a case for that issue with TAC at http://www.cisco.com/tac
s.matyas Mon, 09/02/2002 - 03:47
I think I can't understand something clear .I can not allow read only browsing......therefore I can do nothing before I write the correct username/password. What can I do in this situation?
