Warning message
Limitting bandwidth on Ethernet based on IP address
bsivasub Thu, 08/29/2002 - 08:07
sure. You can use Policing/rate-limiting. But since you didn't specify any specific products, I can can't comment further.
bsivasub Fri, 08/30/2002 - 18:22
cat6k if you have PFC can also do policing. i am assuming that your cat6k is just layer 2 since you are using 7500. Your option would be do car on 7500 if you don't have pfc on cat6k
