lindborg Sat, 08/31/2002 - 22:32
  • Cisco Employee,
you mean on the forum? Not unless the folks running the forum decide to export it for you to a text file or something... I kinda doubt they'll be willing to do that for folks since they have the advanced search function that should let you find what you're looking for out here.
scottiptel Sat, 08/31/2002 - 22:44
yes you are correct all the forum posted. Yeah search is there but its not that specific,
lindborg Sun, 09/01/2002 - 07:43
  • Cisco Employee,
What kind of specificity are you looking for exactly? You'd probably have better luck pushing for some search engine improvements than getting them to export the raw content for you...
