Warning message
Any way to sniff traffic on 1900 series switches?
Sep 3rd, 2002
since SPAN is not a feature in the 1900 series is there another way or product that can generate traffic to a centralized monitor station on 1900's?
Prashanth Krishnappa Tue, 09/03/2002 - 15:13
  • Cisco Employee,
The only ways I can think of is
1)if you have a hub in between the switchport and the device. You connect the device and the sniffer to the hub.
2)If you have a inline sniffer, use it
glen.grant Thu, 09/05/2002 - 07:31
  • Purple, 4500 points or more
What model 1900 are you using , 1924's have span or monitor capability . It's right on the menu under the monitoring function . From the CLI interface config mode it is the monitor-port comand .
