Admin Password problem after ES upgrade.
Sep 9th, 2002
While using Cm 3.2.2c and upgrading to ES 2.2.3.b I have lost access to CCMAdmin/main.asp Instead of getting the standard login pop-up window, I now get a web based Administrator access window and it does not recognize my admin password. When I try other valid "users" it tells me that they do not have admin access (which they shouldn't) But I do not know why it does not recognize my admin password. TAC has had me reset the passwords in the services as well as re-installing the +COM services but this has not solved the problem. Does anyone know how to get this password reset? Oddly enough the same login/password works for BAT and Win 2k and SQLSvc (the Subscriber is getting updated) Thanks in advance.
Overall Rating: 5 (1 ratings)
j.sillers Mon, 09/09/2002 - 10:35
Perfect!!! Now how come TAC didn't catch that? I havn't used the Multilevel Admin feature before. How will this affect other login features? Do I have to change anything on the Subscribers?
Thanks for your help.
Ginger Dillon Tue, 09/10/2002 - 16:27
  • Blue, 1500 points or more
Also - MLA must be reinstalled after applying a CallManager upgrade.
