Warning message
Multiple Logins
Sep 9th, 2002
When I access the saweb pages I am prompted to login. I login with my unity admin account etc.. Then when I go to the subscibers page it ask me to login again. After 3 times of logging in I get what i need the problem is that I am continously running out of connections because of all the logins. Any Ideas this is 3.1(4).
afuller Mon, 09/09/2002 - 10:09
You're logged into a machine that's in a domain your unity box isn't in. That login box will pop up everytime you access a page that has the Media Master on it. Go into your Tools menu to Internet Tools, and make sure Custom Level > User Authentication > Prompt for user name and password is selected for the Internet and Local intranet zones. That may help cut down the number of times you get prompted to login.
adam
