Warning message
Cant get 3rd interface to be seen on PIX 515
Sep 10th, 2002
Here is the info from Sh Ver
Hardware: PIX-515, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54fe.ef68, irq 10
1: ethernet1: address is 0050.54fe.ef69, irq 7
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 3
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
Serial Number: 403480639 (0x180ca03f)
Its as though the Card is not installed. Its in there. Does it matter what slot it is in??
Scott<-
steve.barlow Wed, 09/11/2002 - 06:11
  • Silver, 250 points or more
Did you install it in the top slot? If no, place it there. It's not a gig card is it - they aren't supported in 515s.
Steve
