Warning message
VPN tunnel between PIX and 2600 on private address??
awaheed Thu, 09/12/2002 - 15:31
  • Cisco Employee,
Hi Phelps,
If you are doing a One to One Static NAT translation for the PIX firewall, then this should work without a problem, but if the device in front of the PIX is doing PAT then it would be a problem to do...
PIX to Router IPSec VPN sample:
http://www.cisco.com/warp/public/110/39.html
Hope this helps,
Aamir
