Warning message
ISDN PRI Dialin - 7206VXR W/ PA-MC-4T1
Sep 13th, 2002
I have a 7206 VXR that currently terminates DSL and L2TP connections. I have added a PA-MC-4T1 card to terminate 2 T1 point to point lines. Can I add a PRI and accept incoming ISDN multilink ppp calls? Can I accept any V.90 calls without adding an AS5300 or similar access server. Where might I find some sample configs. I can only seem to find examples for Cisco Access servers, not 72XX series routers with ISDN / PRI.
Thanks in advance for the help.
Mark
makchitale Sun, 09/15/2002 - 11:25
  • Silver, 250 points or more
Yes, with the PA-MC-4T1 can add PRI & accept ISDN (multilink) calls.
No, there is no way to terminate the analog v90 calls on this 7206vxr (though the calls can come in on the PRI's DS0).....typically need internal digital modem for the same (which the access servers have).
http://www.cisco.com/univercd/cc/td/doc/product/cable/cab_rout/cfig_nts/4815ds1p/4815conf.htm
Thanks, Mak.
