Warning message
Transfer directly misses beginning of greeting
Answered Question
Sep 13th, 2002
We have implemented "option 3" with a cti route point for transferring directly to subscribers mailboxes. However, our Administrative Assistant cannot always hit the Transfer key quickly enough to let the caller hear the beginning of the greeting. Is there a way to have it ring a couple of times first?
I tried changing the line in call manager from Forward All to Forward No Answer, but no delay resulted.
I was sure this would be an issue already discussed, but searched to no avail...
Correct Answer by oliviers about 14 years 11 months ago
Try entering this into the switch file...
[Configuration]
DelayBeforeOpening=
Where is a value in seconds.
I'm not 100% positive that this setting is supported with the CCM integration, but give it a whirl. It will require a Unity restart.
What this setting should do is delay conversation, prompts and/or greetings at the onset of Unity answering a call for the duration specified. This is a global setting and will give the appearance of a "delay" when phone calls reaching Unity don't need the delay.
Overall Rating: 5 (1 ratings)
Correct Answer
oliviers Fri, 09/13/2002 - 08:36
  • Cisco Employee,
[Configuration]
DelayBeforeOpening=
dhellwig Fri, 09/13/2002 - 11:21
This works fine. The file is called Cisco0002.INI in the C:\commserver\intlib directory. It can also be edited with the start-programs-unity-edit switch utility
The value is number of seconds. I went with 2 seconds and it seems fine.
