Warning message
Echo-Cancleation on PRI with MGCP PRI Backhauling
Sep 14th, 2002
  • Bronze, 100 points or more
I have a PRI with MGCP enabled (Pribackhauling) 12.2.11T, 3640, and I have to keep putting the "echo-cancel coverage 16" under the voice port, when I reload the router, the mgcp removes this configuration, I cannot locate this in Call Manager to enable it, does anyone know a workaround?
trailman73 Sun, 09/15/2002 - 07:45
You have to do a shut, no shut on the voice port. If you don't it will not save the config.
geoff
tringwelski_2 Wed, 10/09/2002 - 09:06
This is a bug in the code if your using the config paramater and auto d/l the commands, the echo coverage is removed each time, so do not use the auto config /parcing of the cli , manually enter the info and remove the server config command.
