Warning message
How to turn on level 7 (debugging) syslog option on VPN 3005 or VPN 3002
Sep 15th, 2002
When enabling syslog logging on the VPN 3005 Concentrator, there is only the option to log levels 1-3. On the VPN 3002 Hardware Client, there is only the option to log levels 1-6. Since level 7 is debugging, how can you get this level of logging from either of these devices?
awaheed Mon, 09/16/2002 - 22:57
  • Cisco Employee,
Hi Brandon,
Actually if you want to turn on the Syslog logging on the Concentrator, you can go to: Configuration | System | Events | Classes | Modify on the CVPN3005 or CVPN3002 and turn on the Severity to Syslog to 1-13 for any specific class you want. Additionally go to: Configuration | System | Events | Syslog Servers to configure the specific Syslog servers aswell.
Hope this helps,
Aamir
