Warning message
rmushtaq Mon, 09/16/2002 - 09:44
  • Blue, 1500 points or more
There are no such applications like DFMAD, DFMCP in CW2000. Are you referring to some specific DFM processes in CW2000?
DALI WANG Mon, 09/16/2002 - 12:22
I got these information from "Server Configuration -->About the Sever-->Applications and Versions". I do not know exactly all processes about DFM. I want to how to enable the main DFM processes: DfmBroker, DfmServer, DfmMailNotifier, and so on. (I can not find the processes under "Process Management ")
Thanks a lot.
David
rmushtaq Mon, 09/16/2002 - 12:55
You will only see the above processes under Process Management, if you have installed DFM. Have you installed DFM?
