Warning message
CNR trouble when filtering & ordering DNS RR.
Sep 20th, 2002
I have some problems when ordering or filtering RR in a the DNS zone dialog box (ressources records tabs). These tasks returns wrong lists (I have A and NS records when filtering with CNAME criteria, some of the RR don't locate at the right place...). The zone is quite big : 1639 static RRs & 6570 dynamic RRs.
Is there some known solution about that ?
NB : CNR versions
CNR Server : 5.0.9
CNR Gui : 5.0.9 & 5.5.2.
tcarlo Fri, 09/27/2002 - 06:38
This is in the GUI only correct? Do the nslookups do the requested subnet sorting or round robin?
...TC...
yr_cnr_cco Fri, 09/27/2002 - 07:08
The problems occurs in GUI. I don't use round robin. The nslookup answers are right for the different requests.
I opened a case yesterday via Cisco TAC about this problem : D164512.
tcarlo Fri, 09/27/2002 - 07:17
My feeling is that this command will help you out. The issue appears to be a curruption in the guicache. The command below should be issued at the cli.
Here's a clip from text in the cli guide that sounds like your issue:
Rebuilding Resource Records Indexes
Use the dns rebuildRR-Indexes command if you need to rebuild your resource records indexes. You might need to rebuild your resource records indexes if you observe resource or host list data that appears inconsistent or if data appears to be missing. Rebuilding your resource records should correct any inconsistencies.
Note The dns rebuildRR-Indexes command removes any duplicate resource records it finds in the database. A subsequent reload of the DNS server may produce the following
diagnostic message:
101 Ok, with warnings
Error Protocol Error removing record for name host_name, zone zone_name
while loading config changes.
This warning is to be expected in this case and you can safely ignore it.
The syntax is:
...TC...
