Warning message
wrong CPU load calculation on c1600/c2500
Sep 22nd, 2002
Hello all,
on c2500/c1600 the CPU util is not correct calculated. Due to this (known) problem it is very difficult to monitor the real CPU utilization. Does anybody know how to fix (workaround) this issue. On most of the managed routers I do see a CPU load of approx. 20% (5min) even the router is idle.
Thanks for support.
Brgds
Stefan
beth-martin Fri, 09/27/2002 - 06:56
  • Bronze, 100 points or more
If the show proc cpu is outputting incorrect values, then there is an IOS issue. The only fix I know of is to change to an IOS without this problem. If this is a known issue, there should be a bug ID which would tell you which IOS code has the fix for this. Check the bug toolkit on CCO.
