afuller Mon, 09/23/2002 - 06:49
Make sure the username and password that is used to log that service in is correct. If not, the service won't start. Is the AvDsAD service starting? Are you using the same log on information?
adam
trailman73 Mon, 09/23/2002 - 07:00
  • Bronze, 100 points or more
Yes. It seems that it clears the password when I reboot. I check the logon, and it is using the appropriate user, but the password is not correct. When I manually enter the password, it works fine.
geoff
