Warning message
Call Manager setting
Sounds like you have an issue with your route patterns to be honest. Typically, if you have overlapping route patterns it will cause that problem. For example, if you just use a 9.@ route pattern without any route filters, CallManager doesn't know if you are going to dial 7 digits, or 10 digits or even 23 digits.
Two ways around this, first narrow down your route patterns so that they don't overlap. Second (and the answer to your question), the t302 timer is the timer that determines how long to wait for the timeout. See the below link for additional help.
Rick
http://www.cisco.com/warp/customer/788/AVVID/call_routing.html#bcr
