Apple-BABBLE..... Help!!!!
Sep 25th, 2002
I am completly in the dark when it comes to appletalk. Can someone tell me if I need to configure the Cable-Range the same on each side of a point-to-point serial connection? Also are there any caviots involved in running VoIP along the same route with Appletalk traffic?
Here is the config so far on a 7200...
interface Serial4/0:0
description Connected to BLA_BLA_BLA
ip address x.x.x.x 255.255.255.x
encapsulation ppp
ip mroute-cache
appletalk cable-range 10-10 10.209
appletalk zone WANHOST
no cdp enable
These are a 7200 series router to a 2620 via a frac T. Any pointers or links?
Josh
thisisshanky Wed, 09/25/2002 - 08:14
  • Purple, 4500 points or more
Appletalk is a very chatty protocol, keeps talking every 10 seconds, if you are running RTMP between the routers, which i think, is enabled by default.
Either ends should have the same zone name configured.
VOIP might face trouble with Appletalk around.
