Warning message
Upgrading from a 6509 to a 6513
Sep 25th, 2002
Has anyone had experience moving blades from a 6509 chasis to a 6513. If so, can you retain the configuration of the 6509 (lots of VLAN and port configuration). Will the SUP modules from the 6509 work in the 6513? What is the best migration process ? Can we simply move the modules to the same slots in the 6513 and tftp the config?
Thank you
Prashanth Krishnappa Wed, 09/25/2002 - 17:12
  • Cisco Employee,
What kind of Supervisor do you have in your 6509? 6513 chassis is supported with Supervisor Engine 2 only and the minimum cat OS requirement is 6.2(2)The best code to run would latest 6.3(x)
You shoud be able to move your regular ethernet/gig ethernet modules without any issues. If you have a SFM module in 6509, you'll need SFM2 for 6513
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_6_3/confg_gd/swfab.htm
schnj Wed, 09/25/2002 - 19:32
SUP2's with MSFC2's.
Thanks for your Reply
