Warning message
ACS Configuration
Sep 26th, 2002
I'd need some information on CiscoSecure ACS.
I've read on Cisco's web-site that I can import a text file into the
CiscoSecure, in particular of the format reported below (concerning
mobile IP).
My questions are:
1) in which way can I import such a file? With the command line
interface I've founded a different format..
2)For which release of the CiscoSecure is this format valid?
3) Is it possibile to completely configure the ACS via a
text file? How?
Thank you for your attention and time.
This format can be imported into a CiscoSecure server.
user = 20.0.0.1 {
service = mobileip {
set spi#0 = "spi 100 key hex 12345678123456781234567812345678"
user = 20.0.0.2 {
user = 20.0.0.3 {
Example retrived from this address
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/ip_c/ipcprt1/1cdmobip.htm#40150
thisisshanky Fri, 09/27/2002 - 19:08
  • Purple, 4500 points or more
I think u can use CSUtil.exe to import the file.
