VPN3000 Idle Timeout for IPsec Lan-to-Lan Tunnel
Sep 30th, 2002
Is it possible to limit the time for an IPsec tunnel at the VPN3000 Concentrator for a LAN-to-LAN connection? At the moment the tunnel is always up. Can I bring the tunnel down if there is no traffic?
engel Mon, 09/30/2002 - 05:19
There is a setting for L2L idle timeout. Go to the "User Management->Group".
Modify the L2L Group , and navigate to the General Tab. Enter the amount of time for idle time at "Idle Timeout" setting.
