Warning message
how to grouping object in PIX525
Sep 30th, 2002
I want to group object to deny packets from stock site
(config)#object-group service not_allowed_ports tcp
(config-service)#port-object eq 6788
(config-service)#port-object eq 7777
(config-service)#port-object eq 8082
(config-service)#port-object eq 26119
(config)#access-list 119 deny tcp any object-group not_allowed_ports
is it possible ???
thanks in advance
Overall Rating: 4 (1 ratings)
steve.barlow Mon, 09/30/2002 - 04:06
  • Silver, 250 points or more
Yes, but don't forget source/destination on the acl. This is an example of what I am using right now:
object-group network wizards
network-object 10.0.0.111 255.255.255.255
network-object 10.0.0.102 255.255.255.255
object-group network Admins
network-object 10.200.200.75 255.255.255.255
network-object 10.200.200.76 255.255.255.255
object-group service e_TCP tcp
description TCP Service Group
port-object range 6363 6364
object-group service e_UDP udp
description UDP Service Group
port-object eq snmp
port-object eq snmptrap
access-list inside_access_in permit tcp object-group Admins object-group wizards object-group e_TCP
access-list inside_access_in permit udp object-group Admins object-group wizards object-group e_UDP
Hope it helps.
Steve
