MWI not lighting for some users
We are using Unity ver. 3.0. With one user I'm unable to save the change to "Use MWI for Message Notification". As soon as I try to save it, the check disappears from the checkbox. I'm also not able to add a MWI extension.
For another user, the above symptoms do not show up; everything appears normal, but no light when a message is left.
Thanks for any help.
