Warning message
trunk busy out
Oct 2nd, 2002
I have two GWs setup for CCM, one is primary, the other is secondary.Is there a way I can busy out T1 trunk on the primary so that I can test failover? For example I would like to disable 23 channels and only leave one channel there, so if I make two calls, the seond one should go from the secondary GW.
