Warning message
object-group command for udp and tcp ports
Oct 4th, 2002
Just checking on this command:
object-group service grp_id {tcp | udp | tcp-udp}
and the description of tcp-udp
Specifies that service group can be used for TCP and UDP.
Is there a way to use this or some other combination to add UDP and TCP ports to the same service group vs. opening up both UDP and TCP to the ports listed.
For example you may want to have UDP 88 and TCP 445 in the same group but not UDP 88, TCP 445 AND TCP 88 and UDP 445.
thisisshanky Fri, 10/04/2002 - 13:06
  • Purple, 4500 points or more
in cases where you want both udp 88 and tcp 88 and tcp 445 and udp 445, you can go for the tcp-udp clause
otherwise you should specifically define them with tcp or udp clauses
for ex:
config)# object-group service test tcp-udp
(config-service)# port-object range 1024 65535
(config-service)# exit
This helps in defining a object group by name test, which specifies a range of Tcp and UDPports, which can be used in ACLs or conduits.
